What do you guys think of this monitor? Claims to have really clear colors on a TN panel which is odd, I wonder if its just super saturated? But its 1440p and 144hz in 27 inches which is prime sizing for that resolution. And look at that price! VESA compatible and G-Sync compatible? I am getting lost on this whole G-Sync thing to be frank. They have a list of approved monitors, yet it seems a bunch of Freesync monitors seem to allow G-Sync to be turned on anyways? Anyone that can explain this to me better?
Currently I have this monitor, and I quite like it, but it would be nice to have a slightly bigger screen and more resolution. Current monitor claims 1ms response times, where as the Viotek claims the same with overdrive and more like sub 4ms response time. Is it worth the upgrade? Thinking I can sell the Acer for around 125-150 depending on if the seller checks the price history on Amazon.
My First (Current) Build:
Ryzen 7 2700 (3.90 1.35v OC) | Asus Prime X470 Pro | G.Skill Ripjaws V 16gb 3200 | Inland Professional 512gb M.2 NVME | Samsung 860 Evo Sata M.2 1TB | Corsair H115i Platinum | Corsair ML 140 RGB Fans | Fractal Design Meshify C | EVGA RTX 2070 XC Ultra
Laptop:
HP Spectre X360 13t Gem Cut (i7 8565u, 240gb, 8gb mem)
My Ride:
2015 VW Golf TDI Sportwagen
Eventually an XJ manual...
https://linustechtips.com/topic/1104480-viotek-gft27db-monitor/
Bump
Laptop:
My Ride:
https://linustechtips.com/topic/1104480-viotek-gft27db-monitor/#findComment-12893796
