Ghosting on my Samsung C24FG73
It's a 144hz 1920x1080 VA 24 inch panel with "1ms" response time. It has a normal, fast and fastest response time mode and low input lag mode and I have it on the fastest and low input lag mode on. Im pretty sure these settings dont change the ghosting but when I am playing kovaak's aim trainer or overwatch I feel like the enemies are blurring past. I know I have motion blur turned off and it looks like ghosting. Enemies are usually red or red outlined if that helps?
Just want to know some general monitor tips to make better/ specific things to fix ghosting.
https://linustechtips.com/topic/1104452-ghosting-on-my-samsung-c24fg73/
Try the fast option,I am pretty sure one of those options is responsible for it.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
IF its ghosting, it can be either normal ghosting or inverse ghosting aka overshoot.
The later is caused by to much overdrive.
VA panels have a particularly hard time with dark transitions, however a good VA panel should have no issues with lighter transitions.
again IF its ghosting ur experiencing, try lowering the overdrive.
overdrive is good for attempting to compensate for the slow dark transitions, but it overdrives ALL transitions, which can lead to overshoot in the lighter transitions.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
When was it working good ?  What happened since then ?
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
I'll try normal and fast modes then :)
Just now, Remikp04 said:
Honestly no idea, if anything I reinstalled windows but that shouldnt change anything right?
Well it can, since the drivers are older.  Use DDU then install the latest nVidia drivers and let us know.
17 minutes ago, Remikp04 said:
DDU? Also I have latest nVidia drivers
Ok cool, I wanted to make sure you were on latest drivers after install OS or updating it.  Is there a game that works or this happens with everything ?
Drivers has nothing to do with ghosting issue.
It has to be monitor's settings or you got a bad lottery.
DAC/AMPs:
Klipsch Heritage Headphone Amplifier
Headphones: Klipsch Heritage HP-3 Walnut, Meze 109 Pro, Beyerdynamic Amiron Home, Amiron Wireless Copper, Tygr 300R, DT880 600ohm Manufaktur, T90, Fidelio X2HR
CPU: Intel 4770, GPU: Asus RTX3080 TUF Gaming OC, Mobo: MSI Z87-G45, RAM: DDR3 16GB G.Skill, PC Case: Fractal Design R4 Black non-iglass, Monitor: BenQ GW2280
Honestly dont know think its the same with everything
I never said that Im not that stupid here,, come on now........
Were simply trying everything we possibly can.
