Cleaning a modern gaming flat panel?
@Dacobi
Damp soft cloth.
Dont use cleaning products.
LCD displays that dont have a glass front (which is the vast majority of them) have a porous surface, meaning liquids can leach through, as such some cleaning products can damage the screen.
The safest method is to just use a soft cloth made damp with plain water.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
2 hours ago, Dacobi said:
What about the store bought remedies that containing only water and sodium lauryl sulfate?
It it states its safe for cleaning LCD screens then go for it. SLS 'shouldnt' cause any issues.
Personally though i just stick with the safest method.
