Wi-Fi extender ; Ethernet ; how to connect ?
What's the model number? I get the feeling you're misunderstanding how Wi-Fi extenders work.
https://www.amazon.in/gp/product/B0195Y0A42/ref=ppx_yo_tab_ap_asin_title_o02_s00?ie=UTF8&psc=1
I’ve setup the pseudo Wi-Fi ..it works gr8 ...But how do I connect it via Ethernet (it has a Ethernet port like all extenders do)
It looks like that Ethernet port can be used in one of two fashions. If the extender is in AP (Access Point) mode then that port is meant to connect the the router as a source of Internet. When set to run as a Repeater the port will act as a source of Internet for a wired client.
So you probably have it in the wrong mode or the Repeater isn't connecting to your router. One or the other.
Well the router is connected to the EXT .and  is up working ...even now i’m Connected to the extender.  But the Ethernet isn’t working using a cat 5e
I would say then there's something else were missing here. I can't pull up the repeaters user guide right now. It'd be pretty helpful. I'd say verify what mode it's in and reread how to configure the Ethernet port.
wifi extender is not wireless router, you need at least one wireless router to work. altho routers do have extender function.
for more complex layout is better to use powerline adapter
why everybody post the spec of their rig here? i dont! cuz its made of mashed potatoes!
Quick update:  My Ethernet cable is faulty .lol..anyways thanks
Unexpected but that'll do it. Need help with anything else while you're here?
Nothing as of now ...i’m Happy with this extender .....i’m Seeing a boost of upto 2.5 times ...
before: 22 mbps tops
extender Wi-Fi : 50-55 mbps
extender Ethernet : 70-75 Mbps (exactly what I pay for)
thanks 4 d help tho .... :)
