This will be my first post on the Linus Tech Tips forums! Whohew ye buddy!
I was just wondering, what would it look like to have a hardlined pc submerged into mineral oil? Such as red dyed water through hardline, to a radiator and pump and whatever else, just as if it was a normal water loop, but built in a tank filled with mineral oil. I am sure it would look very cool, but not practial at all. Maybe this could be a video for the LTT team to do?
https://linustechtips.com/topic/1104194-hardline-in-mineral-oil/
Welcome to the Forums!
It has been asked many a time before, short term a setup like that would look great but long term it won't last due to the seals and tubing degrading in the mineral oil itself. Not to mention the need to maintenance a watercooling loop when submerged is not exactly easy.
^^^ LTT has also done a mineral oil PC in the past (not a custom loop inside one, using the oil itself to cool the PC IIRC). Maintenance was horrible due to everything being covered in oil and reliability was eh for the same reasons W-L mentioned. PC components aren't really built to be submerged in oil.
Main PC
CPU: i5 12600KF
Cooler: Noctua NH-L12S
Motherboard: ASRock Z690 ITX/ax
RAM: 2x16GB 3600Mhz DDR4
GPU: Intel ARC A770 16GB LE
Storage: 1TB MP34 + 2TB P41 + 2x 1TB MX500
ODD: LG WH14NS40
PSU: EVGA 850W GM
Case: Silverstone Sugo 14
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 15" M3 MacBook Air (work) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, flash, running Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2022 Kawasaki KLR650
it can be done for sure, but it will be a right PITA to ensure the o-rings dont degrade. Ull have to identify the o-ring materials being used, make sure they are ok in the oil ull be using. If not ull then have to source new ones that can be used with the oil.
Then ull have to deal with the 'issues' one has with ur average oil submersed PC.
its alot of work for a gimmick.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
