Lines going down the middle of my monitor sometimes
my AW2518HF randomly gets these lines running down the middle of the monitor (pic one and two)
It always happens in the same place for example, if I'm playing a game and the line in the middle of my monitor appears I can just look to a different location and it goes away, but if I look at that exact location again it appears. I can always get the same results if I know where to go or what programs make it happen.
this does not happen with my other monitor only the AW2518HF.
I've tested to see if it happens with two other display ports and an HDMI and it does still happen.
I should also mention that if I know for example what location in a game and where I was looking I can go back there and it always happens again.
the lines also always appear in the same place on my monitor and look the same.
Is it still under warranty? I would just RMA it considering it happens with multiple cables and ports, probably just something wrong with the panel itself.
why no dark mode?
Current:
Asus ROG Flow Z13 (GZ301ZE):
CPU: i9-12900H @ Up to 5.0GHz all core
- dGPU: RTX 3050 Ti 4GB
- eGPU: Radeon 6850m XT XGm 16GB
RAM: 16GB (8x2GB) @ 5200MTs
Storage: 1TB NVMe SSD, 1TB MicroSD
Display: Internal 1200p@120Hz, Asus ROG XG-17 1080p@240Hz (G-Sync), Gigabyte M32U 4k@144Hz (G-Sync), External Laptop panel (LTN173HT02) 1080p@120Hz, Asus VG248QE 1080p@144hz
Watercooled Eluktronics THICC-17 (Clevo X170SM-G):
CPU: i9-10900k @ 4.9GHz all core
GPU: RTX 2080 Super (Max P 200W)
RAM: 32GB (4x8GB) @ 3200MTs
Storage: 512GB HP EX NVMe SSD, 2TB Silicon Power NVMe SSD
Displays: Internal 1080p@300Hz
Custom Game Server:
CPUs: Ryzen 9 9900X
RAM: 128GB (4x32GB) DDR5 @ whatever it'll boot at xD (I think it's 3600MTs)
Storage: 2x 1TB WD Blue NVMe SSD in RAID 1, 4x 10TB HGST Enterprise HDD in RAID Z1
