So im looking to buy a new gpu and i was wondering if the rtx 2060 would go kinda well with my a little bit overclocked i5 3550
i've checked online and it seems like the bottleneck won't be that high (i usually play cs:go and sometimes overwatch and maybe rainbow six)
i know that the gtx 1660 would probably be a better choice or even the gtx 1060 6gb or the gtx 1650 but i am looking to upgrade my cpu in the kinda close future. (maybe i7 9700k or 8700k)
and i want this gpu to last a couple of years for my younger brother (even if i wont upgrade the cpu)
"I fear not the man who has practiced 10,000 kicks once, but I fear the man who has practiced one kick 10,000 times." - Bruce Lee
https://linustechtips.com/topic/1104045-rtx-2060-and-i5-3550/
Just now, alatron978 said:
Depends on your fps target, if you want 60fps and only game you will be fine, but if you want higher fps, i defiantly would recommend an upgrade.
my fps target is 70 - 100 maybe 120 or 144 if i get a new monitor
https://linustechtips.com/topic/1104045-rtx-2060-and-i5-3550/#findComment-12889568
