I have a Corsair 1000D which stands in the corner of my office. It's under my desk so the top has a clearance of ~2cm (euhm, guess that's 1" :P).. I've noticed that the heat builds up atm with my AIO, which is mounted at the top of my case, and aftermarket GPU cooler. So I'm watercooling the system (components arrived), but I wonder how I best place my radiator and its fans. I was thinking of placing it in the front of my case with the fans pulling air from the case (So you would have this - FANS -> | RADIATOR -> | FRONT OF CASE). Or should I turn it around, but I'm scared that the heat will build up again.
https://linustechtips.com/topic/1103703-radiator-position-and-fan-direction/
can you get the fans on the other side of the rad even? and how much of a gap would that leave before the front panel? you need to make sure the fans have plenty of space infront of them if they are going to do their job well. The plan you have now should work fine and is probably how i would have done it
Builds:
The exhaust would be the 2 gaps at the side of the front. So fresh air would be pulled from the top automatically (no fans - might add later) and the fans push the air from the case out through those gaps.
@rafbanaan
The 1000D is a monster case designed for ALOT of water cooling.
I'd probably go with to top intake front exhaust in ur situation.
2x 480mm rads in he front as exhaust. remove the dust filter.
And the top as intake with 3 140mm fans, filtered.
I'd buy a magnetic dust filter for the rear 2 x 120mmms fans as intake as well.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
53 minutes ago, SolarNova said:
@rafbanaan
For the moment I have a single 480 rad for in the front. I wanna see what that gives first before buying a second one :) I do have a spare of 4 ML120's which I want to use at the top.
But the 480 rad in front with the fans pushing the air out the case is not a bad plan?
Not a bad plan at all. I used to run front exhaust on my old case (CM Storm Stryker).
Just ensure that any exhaust fans are unfiltered and any intake fans are filtered.
