Time to replace my 7 years old workhorse. After couple of days researching, threw together this part list, mainly for gaming / coding. Is it ok for 1440p 144hz?
Would like to try some light CPU/RAM overclocking for knowledge and some performance boost. Guess I would need cpu cooler and some extra fans, besides the 2 stock ones that come with the case? Any recommendations?
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (€194.90 @ Caseking)
Motherboard: MSI B450 GAMING PRO CARBON AC ATX AM4 Motherboard  (€140.89 @ Alternate)
Memory: *Crucial Ballistix Sport LT 32 GB (2 x 16 GB) DDR4-3200 Memory  (€150.89 @ Amazon Deutschland)
Storage: *Crucial MX500 1 TB M.2-2280 Solid State Drive  (€109.47 @ Amazon Deutschland)
Video Card: Sapphire Radeon RX 5700 XT 8 GB PULSE Video Card  (€443.89 @ Mindfactory)
Case: Fractal Design Meshify C ATX Mid Tower Case  (€98.89 @ Alternate)
Power Supply: be quiet! Straight Power 11 650 W 80+ Gold Certified Fully Modular ATX Power Supply  (€109.98 @ Mindfactory)
Monitor: LG 27GL850-B 27.0" 2560x1440 144 Hz Monitor  (€579.00 @ Amazon Deutschland)
Total: €1827.91
Generated by PCPartPicker 2019-09-11 21:44 CEST+0200
https://linustechtips.com/topic/1103545-ryzen-5-3600-5700-xt-build/
Total: €1827.91
Great build.  Just note that you might or will have to flash the BIOS with button in back of motherboard and usb stick and what not, to make it compatible with 3xxx series.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
Would perform pretty well for 1440p 144Hz. As for coding, do you mean compiling huge programs or just typing Java stuff?
Primary PC:
Do you really need 32GBs of RAM? As 16GBs with 3600mhz speeds will be better for performance, assuming the upgrade from 3200mhz isn't expensive.
I'd probably just go for the R7 3700X
you can get a non XT card and flash the bios for free performance.
Seems a bit much for just a 1440p 144hz display, why not go for an ultra wide? They're cheap in the US anyways.
Get the Crucial P1 instead. It's significantly better than the SATA SSD and only a tenner more.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Yes, I am aware of that, thanks for the heads up though.
Just now, DDDen said:
Glad to hear. No huge compilations - gaming should be more resource intensive.
In which case, 16GB is more suitable. You can opt for 3600MHz, or just pocket the savings.
Primary PC:
32GB is more for future proofing, and judging by the videos/reviews I watched - these Ballistix sticks should be able to reach 3600.
Did not know about the non XT bios flash, found the reddit post, going to check it out.
More than 27" is too much for me + 2nd monitor is left from the old setup (although its a 1080p)
3 minutes ago, DDDen said:
There's plenty of cheaper 1440p 144hz options in any event. This one just lacks adaptive sync, which isn't too big of a deal for a 144hz display. 300 EUR.
Could entirely eliminate your 2nd display with an ultra wide too though, a lot of them have support for automatically splitting the display in half for productivity stuff.
https://de.pcpartpicker.com/product/qnqhP6/samsung-lc27jg50qqnza-270-2560x1440-144hz-monitor-lc27jg50qqnza
Good call. At first I was looking at ADATA XPG SX8200 Pro, but shelved it as the benefits of NVMe did not justify €50 difference with MX500 to me.
Depending on what kind of coding/programming you're doing a nice NVME drive is going to help a bit, don't have to go as crazy with PCI-e 4.0 RAID 0 here
Valid points. Haven't seen this one as was filtering only for IPS monitors from the start.
Thanks for suggestions, will be checking the ultra wides as well.
This one's 600 EUR on the part picker. Dunno if it's just limited but we can get those kinds of displays for $400 USD over here.
https://de.pcpartpicker.com/product/PLjJ7P/benq-ex3501r-350-3440x1440-100hz-monitor-ex3501r
https://www.tomshardware.com/reviews/benq-ex3501r-curved-freesync-hdr-gaming-monitor,5621.html
The Sabrent Rocket is better than the Crucial P1.
https://de.pcpartpicker.com/product/N7zkcf/sabrent-1-tb-m2-2280-solid-state-drive-sb-rocket-1tb
Yeah. I mean the SX8200 Pro is vastly superior on paper, but I doubt you'd notice it in day to day use.
But for a tenner, the P1 just makes total sense. Even if you might not notice the difference...there's always a chance. It does load games ever so slightly faster ?
