How to clean rust of a graphics card?
Go to solution Solved by Kaupas24,
thanks Master Disaster
Where is the rust, I am not seeing it.  Then again I am old.
Also, be careful taking it apart. You have a screw that's stripped a little.
Onyx: AMD Ryzen 7 7800x3d / ASRock Taichi 7900xtx OC / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 1000 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
OnePlus Ecosystem:
Other Tech:
White vinegar and a cue tip.
Main Rig:-
Server:-
