XMP 2.0 GSkill DDR4 Problem | Ryzen 3600 | ASRock B450M Steel Legend
i've just bought a Ryzen 3600 and the ASRock B450m Steel Legend Mobo to upgrade my gaming rig, with that i use my old Ripjaws V 3000 DDR4 8GB×2.
Now it runs on dual channel and every XMP 2.0 Profile up to 2933mhz works fine but it stops working on the 3000mhz setting, i basically get a black screen and no BIOS access. I have no clue on how to get my frequency to 3000mhz..is there even a way to make that happen? Seems to me like there isn't a way since every other option under 3000 works fine :/
cheers:)
So if they work fine under 3k, then go with the fastest setting that doesn't break.
Problem solved.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
Problem solved.
but still.. the ram is rated for 3000mhz.. it should run at the XMP profiel right...
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
Nooop. Steel legend is garbage with memory.
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
Oh I meant the ram. Yeah havent heard good things about the steel legend, wasnt ware how far it affects the memory
@Suri412 unfortunately from experience I can tell you that the steel legend seems to refuse to go above 2933 across the board, I had a similar experience when I had mine
