Seasonic S12II 430w for a R5 2400G build
Go to solution Solved by astranger200,
7 minutes ago, Intekss said:
I was told that is a bad unit, outdated design, shouldn't use it with modern component or for a gaming rig, etc so idk.
and sorry for not explaining things clearly.
they are an older design and do have some downfalls but overall are ok quality and I havent seen too many people having issues with them. for a low powered apu build its fine
11 minutes ago, Intekss said:
Is from my main PC and idk what to do with it so i was thinking reusing it for an APU build.
im missing the point of this post?!? it will work fine if thats what you are asking
My rig: r7 1700 @ 3.9/1.35v, 16gb ddr4 3200, assorted rando SSDs, hx 1050, vega 64 1650/1025
MY $75 BUILD https://linustechtips.com/main/topic/576889-the-75-build-log/#comment-7547280
As Long As The PSU Is Fine, It Should Be Perfectly Able To Handle The Ryzen 5 2400g And Motherboard Etc.
Just Be Careful If You Choose To Add A Gpu Later Down The Line, You Always Want To Have 100W~ Headroom Just Incase. However For Just An Apu It Will Be Perfectly Fine.
I hope that I was able to help 🙂
Thanks, much appreciated.
I run a pretty similar PSU myself and am able to power a GTX 960 from it along with a Haswell i5. Not exactly power hungry hardware by 2015 standards. A Ryzen APU should certainly draw quite a lot less.
My eyes see the past…
My camera lens sees the present…
i was using it with an OCed x3440 and r9 370x (similar to r9 270x)for couple year...
