So I have this problem with CS. As a benchmark I use deathmatch on dust 2. While playing I get around 100-120 FPS with dips as low as 60. Now bear with me. Those numbers do not change no matter on settings. It's the same when maxed out in 4K (yes, I'm the kind of person that plays in 4K at 60Hz :D) and with everything at lowest at 640x480. XboX DVR is obviously OFF. I have all of CPU power saving features turned off in BIOS. I reverted my CPU's OC also. But no still no luck. Can anyone relate to this problem? Also, my specs are on my profile.
https://linustechtips.com/topic/1102886-too-low-fps-in-csgo/
That tends to make performance worse
List your system specs first?
Desktop benching:
https://linustechtips.com/topic/1102886-too-low-fps-in-csgo/#findComment-12879381
15 minutes ago, Wierzbak said:
i5-3570K, GTX 1070 Super JetStream.
Also, I have 12 gigs of RAM (1x4 +1x8) slotted in two separate channels ofc.
CPU and likely memory bottleneck I'd say, but dipping to 60 is still worse than expected. Check the temperatures.
Desktop benching:
https://linustechtips.com/topic/1102886-too-low-fps-in-csgo/#findComment-12879468
Is RAM usage above 8GB? Also put the CPU overclock back on.
Desktop benching:
https://linustechtips.com/topic/1102886-too-low-fps-in-csgo/#findComment-12879553
42 minutes ago, Wierzbak said:
Nope, it sits at around 5,5 GB.
I blame the video driver then. Uninstall with DDU, then reinstall the newest version. If this doesnt work, repeat with older drivers.
Desktop benching:
https://linustechtips.com/topic/1102886-too-low-fps-in-csgo/#findComment-12879695
Turned out my driver has been outdated. Updated, still the same. Reverted 2 versions, still the same.
https://linustechtips.com/topic/1102886-too-low-fps-in-csgo/#findComment-12879858
use GPU-Z to check the PCIe connection. If you use Z77 board you should get PCIe 3.0, otherwise 2.0, both x16.
Desktop benching:
https://linustechtips.com/topic/1102886-too-low-fps-in-csgo/#findComment-12879872
7 minutes ago, Wierzbak said:
PCIe x16 3.0 @ x8 1.1 it says.
put some load to it, say run a game.
Desktop benching:
https://linustechtips.com/topic/1102886-too-low-fps-in-csgo/#findComment-12879944
10 minutes ago, Wierzbak said:
Running furmark at 7680x4800 and 8x MSAA. What now?
check the PCIe connection again.
Desktop benching:
https://linustechtips.com/topic/1102886-too-low-fps-in-csgo/#findComment-12879981
and dont run Furmark, it burns cards in the past and now cards actively throttle themselves when they see Furmark.
Desktop benching:
https://linustechtips.com/topic/1102886-too-low-fps-in-csgo/#findComment-12879982
1 minute ago, Wierzbak said:
PCIe x16 3.0 @ x8 3.0. Should I try with other program than furmark?
try reinstalling the card into the PCIe slot.
Even a game would do.
Desktop benching:
https://linustechtips.com/topic/1102886-too-low-fps-in-csgo/#findComment-12880020
Alright, tried reinstalling the card. Also while doing that I ran CS using integrated chip at this lowest possible settings, and fps were lower, but the gameplay felt smoother. After reinstalling the card I ran CS and the reading is PCIe x16 3.0 @ x8 3.0
Also, the problem persists. What now?
https://linustechtips.com/topic/1102886-too-low-fps-in-csgo/#findComment-12881055
only x8? not x16?
I assume the graphics card frequency is still above 1.8GHz
Desktop benching:
https://linustechtips.com/topic/1102886-too-low-fps-in-csgo/#findComment-12881398
