Search In
  • More options...
Find results that contain...
Find results in...
MSI B450 Tomahawk MAX, random no post
Hi everyone.
I build my Ryzen 3700x about a week ago today and its been running great, 3600 CL16 XMP worked on the first boot and so far i have just been running things on Auto (except for XMP).
My GPU for some reason always spins the fans up to 100% for 2-3s on every boot (Palit RTX 2070S Super JS). When i booted the PC for the first time today i noticed that the GPU fan just kept spinning at 100% and nothing happend. Held the power button and turned off the system, next boot it started up as normal with the fans just spinning for a few secs like "normal".
Anyone else that have exprienced this? I mean everything works now, but seems rather odd that it just wouldnt boot on the first go today.
Ryzen 7 3700x, MSI B450 Tomahawk MAX, 16GB Ballistix Elite 3600MHz, MSI RTX 2070 Super Gaming X Trio, Corsair RM750x V2
19 minutes ago, Hemanse said:
Hi everyone.
When you do post go to BIOS and set everything to defaults or optimized defaults and let us know.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
The PC does post and everything is on auto, the only thing I changed right when I first booted a week ago after building, was the XMP profile.
It was just one time, but the PC posts now.  Closed it down and booted up a few times again with no problems. I just found it kinda odd that it all of a sudden won't post and that maybe other people with Ryzen builds might have seen something similar :)
I think there are debug LEDs on the Tomahawk, so if it does it again, might be an idea to have a look at those.
That the fans spin up on every boot
is normal.
So first boot boot didn’t go well, but now it just boots as normal? Could be a single glitch
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 16GB 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
is normal.
Well that is good news OP.
is normal.
I have booted just fine from when i build the PC. The PC have been booting just fine from last monday, it was only today it randomly just didnt boot. I guess it could have been a glitch, only thing different is that i set the AMD balanced power plan and the PC went into sleep mode yesterday, woke it up and closed it down. I guess it could be related to that.
In terms of the fans spinnign up, that seems to maybe be motherboard related. Palit says that they normally dont have the fans set to spin up during boot, but they have gotten a lot of reports from Ryzen 3000 users that their cards does it. I guess it could be BIOS related.
Disabled sleep mode for now, i always disable it, but forgot to when i put it into AMD balanced mode :)
Yeah if it does it again ill have a look at the DEBUG leds. I also added a offset of 0.1v now. It seems crazy that Auto has 1.48v set as the max boost voltage.
Newegg
