Headphone Static Noise due to Ground Issue?
So I recently just bought myself a pair of good value Noise cancelling headphones (Edifier WB860NB), and currently im plugging it through the included 3.5mm cable to my PC,
and through the headphones im wearing a static noise in the background (if i switched on Noise Cancelling on the headphones).
However, when I accidentally placed my hand on the case, the static noise disappeared. I also have a card reader connected to the bottom of my desk, if I make contact with it, the static goes away as well.
So, how do I "ground" my PC, or even the disk-reader, not really sure whether anyone had encountered this problem before.
Currently using the corsair vs550 if not mistaken. Plugged into a 5 gang extension cord.
https://linustechtips.com/topic/1102529-headphone-static-noise-due-to-ground-issue/
19 hours ago, Evanair said:
Does it happen on both rear AND front ports for your headphone jack?
Also, what PowerSupply are you running?
Did not try the rear port yet.
Currently using the Corsair VS 550.
Yes give it a try won't hurt.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
