5 minutes ago, maroammar said:
An R7 2700 or R7 3700X is going to be cheaper, and still perfectly fine for what you're doing.
and the motherboard can either be a $100 MSI B450 board with USB bios flashing, or a ~$175 Asus Prime X570 board.
Doesn’t adobe prefer intel for some reason?
I agree tho, a 3700x/3800x + B450
tomahawk or X570 aurus elite would do fine too
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
It can utilize intel quick sync, but I'm not sure that's worth the extra $150 when Ryzen will do the job fine. Also depends on the codecs you use, and if it's just 1080p footage it won't really matter.
16 minutes ago, maroammar said:
Do you already have the RAM? Because Ryzen 3000 in particular can scale up to DDR4 3600mhz.
i have 3200 mhz g skill ripjaws
i cant understand
Just now, maroammar said:
i cant understand
Ryzen will do the job just fine and is cheaper, or at least should be a lot cheaper than the i9 9900K + Z390 board.
One more potential advantage on going Zen 2 is you could later upgrade to 12 or 16 cores with it. On Intel side, there is a rumoured 10 core part coming but it may or may not need a new socket, so might not be an option anyway.
That ram will be totally fine with amd ryzen.
also ring bus... which for rendering won't make that huge of a difference, but fpr scrubbing sure will. I'd still say intel is the best choice here
