Hey LLT Forum! Hope everything is great with all of you :)
So I have bought a Ryzen 9 3900x and some G.Skill 16GB 3600MHz CL14, now to pair everything together with a motherboard and my corsair H115i cooler. I initially looked at ASUS ROG CROSSHAIR VIII HERO X570 but that wast mostly because I have gone with Asus products before, but is there any reason that I should go with something els? Like the Gigabyte X570 AORUS MASTER and then I would also get WiFi (not that I would use it that much).
Let me know what motherboard you would combo it all together with and why :)
Thanks in advance!
https://linustechtips.com/topic/1102448-what-motherboard-with-3900x/
3 minutes ago, kennethbot said:
The $200 boards are perfectly fine basically.
at that pricepoint the ace, master, crosshair and phantom gaming x look pretty good, so between those I'd just look at the features or role a dice
but something like a tuf or aorus elite, or even a tomahawk/pro carbon is great
