AM4 X570-A Pro Motherboard fan supposed to spin?
Solved by Katze,
3 hours ago, brncrsh said:To be sure, you can try to monitor the chipset temperature with software like HWMonitor, if it goes over ~75C there might be some issues.
Already worked it out, it only turns on above a set temperture, you can lower this in the BIOS so it turns on earlier.
Featured Topics
XianYuDaXian ·
Posted in Linux, macOS and Everything Not-Windows0 -
Regarding the error message encountered during operating system installation on an IBM X3650 server.
Anthons ·
Posted in Servers, NAS, and Home Lab0 -
YagamiNite ·
Posted in Power Supplies1 -
MC.Morrado ·
Posted in PC Gaming1 -
AlDore ·
Posted in Console Gaming1 -
AlDore ·
Posted in LTTStore.com Merch2 -
1
