I just got a X570I ITX board from Gigabyte to pair with my 3900X and I noticed that when I start the PC my 2080Ti's (FE) fans ramp up to maximum speed for a few seconds before Windows starts loading. I know this is normal behavior for some motherboards, but it's excessively loud with the high pitched whine of the GPU fans. I just came from an Asrock Z390ITX board and it didn't do this on start. Is there a way to stop it, or is this just how AMD motherboards initialize?
Cheers.
https://linustechtips.com/topic/1102408-gigabyte-x570i-fan-speed/
1 hour ago, ApplesOfEpicness said:
I just got a X570I ITX board from Gigabyte to pair with my 3900X and I noticed that when I start the PC my 2080Ti's (FE) fans ramp up to maximum speed for a few seconds before Windows starts loading. I know this is normal behavior for some motherboards, but it excessively loud with the high pitched whine of the GPU fans. I just came from an Asrock Z390ITX board and it didn't do this on start. Is there a way to stop it, or is this just how AMD motherboards initialize?
Cheers.
People were getting this happen.  Try at reduce fan speed with AB. Maybe by default for a strange reason ti spins so fast what not not.  Just put a custom curve see how it responds and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
I am already using a custom fan curve. The fan only hits maximum speed before the POST screen.
The MSI X570 board I am using right now behaves the same. my GTX 1070 Gaming X from MSI doesnt make a high pitched noise tho. I guess it could just be something with the chipsets.
I am here to learn, please correct me if im wrong or you see me putting bs on your screen!
