Hello everyone,
My Asus Maximus XI Hero Wifi has a weird problem...
My system has a 9900KF, Corsair Vengeance Pro RGB 3200MHz 64G (16x4), EVGA 2080Ti FTW3 Ultra and Samsung 970 1TB for boot drive
The problem is that when I install 64G of RAM and try to install any drivers, the system will instantly freeze and crash.
However, When I pull out two RAM stick and left with 32G of RAM, the installation runs perfectly and the system never crash.
I check the specification on Asus website and it said the motherboard do support 64G RAM.
I tried to swap the motherboard, GPU and PSU, but they have the same problem.
Please help!
Thank you!
https://linustechtips.com/topic/1102361-asus-maximus-xi-hero-wifi-ram-problem/
is that with XMP off or on?
Primary PC:
Try to disable virtual memory following this options (it's in portuguese but the options are in the same place):
Then, got to your bios settings and check if XMP are all enabled or disabled...
CPU: AMD Ryzen 7 9800X3D; Mobo: Asus ROG Crosshair Hero X670E; RAM: Team Group T-Force 2x16GB (32GB) DDR5 @ 6000MHz CL38; GPU: RTX 4080 - ZOTAC GAMING AMP Extreme AIRO; Case: NZXT H7 Flow; Storage: Kingston KC3000 1TB + Adata Legend 900 2TB; Cooling: Cooler Master PL360; PSU: Corsair HX 1200
16 hours ago, NIH96 said:
Thank you guys!
I checked the QVL, and didn't find my memory kit.
So I decided to go with G-Skill because there are more options in G-Skill and also they are cheaper than Corsair ones....
Thank you for your knowledge!
That's funny, I mean, It shouldn't give you any problems
Update...I just received G-skill Trident Z 64g kit which is on the QVL list.
When I swap the ram and turn it on, wait till the lock screen, the system freeze and crash instantly.
