I've been having issues with this BSOD for a while, and i really need help with it :(
This log is from when the BSOD happened, literally not even 5 minutes ago, when i was trying to install an update for overwatch. Bsod log should be attached.
bsod log.txt
090719-17734-01.dmp
Want any Graphic design or Motion design? Hit me up via the Site, or adding me on skype @ NyxeonFX
So the few things I would recommend.
Check device manager and see if there are any device errors and attempt to correct those
Update the drivers on your system. There are tools to look for driver versions and let you know which ones are out of data.
If you have an overclock remove it
Run a memtest and see if you have a failing stick of ram
Try running a sfc (system file checker) to see if a windows file is corrupt.
Will do, thanks for the recommendations :)
