Hi guys I have a problem deciding between these two models of the RTX 2060s and 2070s. I'm fixed in one of the two betting on ray tracing and Nvidia drivers. My main concern is cooling which is why I have my doubts. Maybe the performance of the two is close enough to go with the 2060s aorus for the better cooling or maybe not? I'm from Argentina and the price difference is around $25usd so I can afford either. What do you say?
https://linustechtips.com/topic/1102254-rtx-2060s-aorus-vs-2070s-windforce/
If your looking at 2060 super vs 2070 super and it’s only a $25 difference get the 2070 super, that’s a no brainer. Hell I’d take a 2070 super founders card over a 2060 super asus strix. Go with the better performance the cooling isn’t worth the downgrade in performance
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Xfx 7900gre
Fractal Ion 2+ 860watt platinum
Be quiet 500dx
Samsung G8 Oled Ultrawide
Aoc Q27G3XMN mini led
Xbox series x
The 2070 Super obviously.
Like stated above if you're on the USA then just buy the Founders Edition straight from nVidia as it is the cheapest and yet it's a perfectly great card.
Personal Desktop":
Luna, the temporary Desktop:
