Hello guys, choosing from 2 rigs right now, dont know with which one to go, want to know other people's opinions, thanks.
1)CPU 9900k
2) MB: MSI MEG Ace
3) Rtx 2080 super palit gamerock
4) Crucial ballistics 16gb
5) PSU corsair rm750x
6) ssd crucial mx500 500gb
7) hdd toshiba l200 1 tb
? be quiet dark rock pro 4
9) case Cooler master mastercase h500p mesh
+ Peripherals 150$ (mouse, headset, mouse pad)
2nd one
1) 9900k
2) aorus elite z390
3) rtx 2080 ti gigabyte windforce/ or manli gallardo version
4)crucial ballistics 16gb
5) psu corsair rm750x
9) nzxt h500
And without peripherals
https://linustechtips.com/topic/1102154-help-to-choose-from-2-rigs/
Can I recommend ryzen 3700x or 3900x? Or do you want intel for a specific reason
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
26 minutes ago, Ivvsu said:
What budget/country, what do you need the PC for, and what monitor resolution/refresh rate?
Ti, every day
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
4 minutes ago, Ivvsu said:
Well im building up just to game, so i think intel will just be better for that
Since zen 2 not necessarily anymore. A 3600 competes with the 8700k
9 minutes ago, Ivvsu said:
Only gaming. 1440p/144 hz. Country is Belarus and budget is around 2800$ incl. a monitor
I have no idea what's available for you then, but here's a german part picker link anyways. I'd highly suggest just getting more best value parts, you really don't need to spend that much on just the PC. The RX 5700 XT can do 1440p high refresh rate gaming just fine.
You could also just get a 1440p 100-120hz ultrawide display.
PCPartPicker Part List: https://de.pcpartpicker.com/list/fpqBgw
CPU: AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor  (€333.90 @ Caseking)
CPU Cooler: Scythe FUMA 2 51.17 CFM CPU Cooler  (€52.90 @ Caseking)
Motherboard: Gigabyte X570 I AORUS PRO WIFI Mini ITX AM4 Motherboard  (€223.99 @ Amazon Deutschland)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3600 Memory  (€92.99 @ Amazon Deutschland)
Storage: Crucial MX500 500 GB 2.5" Solid State Drive  (€63.94 @ Mindfactory)
Video Card: Sapphire Radeon RX 5700 XT 8 GB PULSE Video Card  (€443.89 @ Mindfactory)
Case: Cooler Master MasterCase H500 ATX Mid Tower Case  (€94.97 @ Amazon Deutschland)
Power Supply: Corsair RM (2019) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  (€94.89 @ Mindfactory)
Total: €1401.47
Generated by PCPartPicker 2019-09-07 11:17 CEST+0200
Total: €1401.47
I am guessing you meant to choose the ATX version of that board ?
Total: €1401.47
Thanks for the reply, but im looking for maximum fps and that amount of money that i have will be anyway on pc anyway, due to the specific circumstances (my parents will buy it so it makes no sense getting lower-level pc in my case) So i am just choosing of those two i mentioned, and dont know which one will last longer in terms of 3-5 years and which one is just better.
Then I guess just get the 2nd one with a 9900K and 2080ti, just get a better case that actually has airflow like a Lian Li 011, or Coolermaster H500
