Hi all...
I know that LM is bad for bare coper and aluminium,
but LM between a nickel plated coper GPU water block and the GPU die itself, is it safe and worth to have rather than a high rated thermal paste like Kryonaut?
Should I just use Kryonaut or fk it and go all out with LM for it? What are the pros & cons with LM in a custom loop GPU? It will be mounted vertically if this thing matters.
SILVER GLINT
CPU: AMD Ryzen 7 3700X || Motherboard: Gigabyte X570 I Aorus Pro WiFi || Memory: G.Skill Trident Z Neo 3600 MHz || GPU: Sapphire Radeon RX 5700 XT || Storage: Intel 660P Series || PSU: Corsair SF600 Platinum || Case: Phanteks Evolv Shift TG Modded || Cooling: EKWB ZMT Tubing, Velocity Strike RGB, Vector RX 5700 +XT Special Edition, EK-Quantum Kinetic FLT 120 DDC, and EK Fittings || Fans: Noctua NF-F12 (2x), NF-A14, NF-A12x15
https://linustechtips.com/topic/1101964-lm-on-gpu-with-water-block-safe/
IIRC it’s not really worth it, but I believe it should be fine
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
I wouldn't use LM here because with a lot of GPU dies there's small capacitors surrounding the die itself. If you apply too much and it drips out when the GPU gets hot it may short these and could possibly kill it. With a vertical mount the LM will also try to follow gravity and could seep out all the more.
There's plenty of non-conductive compounds. Arctive Silver Polysynthetic Ceramic comes to mind. Do be careful if you go with that though. I found if you use that and run the system like a crypto-miner the paste will dry, adhere to the die, be very difficult to remove and may kill the GPU. So just watch your temps.
Due to it being direct die cooling you don't see as much of an improvement, and given the risks as others have mentioned it really doesn't make sense to use liquid metal on a gpu, with a good paste you're looking at maybe a 1ºC difference. The real use for LM on graphics cards is shorting shunts to get more power, but you probably don't want to do that unless you don't mind the card dying on you
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
With the voltage ran on some cards it can be worth it on a great wc loop. But the long term pitting on the block and diffuser, I don’t like it. Especially as I tend to keep my hardware awhile and want it decent shape to sell when the time comes.
^^^ It's never really fully removable, is just a headache to apply, and if applied wrong it'll kill the card. Unless you're really, really pushing the card I doubt it's even close to worth it.
I run my Radeon VII on an EK block with Kryonaut paste and Artic thermal pads. Hotspot (the important part, what it throttles based off of) hits about 90C at 1.218v which is the safe max, I could probably push 1.3v for benching runs if I wasn't worried about the longevity of my card. The GPU hotspot normal max is 110C or so on the stock cooler, it throttles at 115C so I'm well below that. LM would at most gain me a couple degrees and IMO that's not worth the risk to a card that cost me $699.
EDIT: oof just saw in the OP you're mounting it vertically, would defo avoid liquid metal. Like the name says it is more or less a liquid, vertical would have too much risk of it heating and flowing somewhere it doesn't belong if you applied even a tiny bit too much (you can use extremely small amounts and there's still excess, a little bit goes an extremely long way).
Main PC
CPU: i5 12600KF
Cooler: Noctua NH-L12S
Motherboard: ASRock Z690 ITX/ax
RAM: 2x16GB 3600Mhz DDR4
GPU: Intel ARC A770 16GB LE
Storage: 1TB MP34 + 2TB P41 + 2x 1TB MX500
ODD: LG WH14NS40
PSU: EVGA 850W GM
Case: Silverstone Sugo 14
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 15" M3 MacBook Air (work) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, flash, running Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2022 Kawasaki KLR650
All voted for no LM.. Approved!
Thanks for the inputs
Off to the build!
SILVER GLINT
Off to the build!
Hell yeah! What GPU and block BTW?
Main PC
CPU: i5 12600KF
ODD: LG WH14NS40
PSU: EVGA 850W GM
OS: Windows 11
Mouse: EVGA X17
SILVER GLINT
