My current PC config is as follow:
CPU = Intel Core i5 3570K
AIO = Corsair Hydro Series H60
GPU = Asus RX 570 4GB(Overclocked version)
PSU = Corsair 750W (Non-modular)
MOBO = Asus P8Z77-I Deluxe (ITX form factor)
RAM = Corsair Dominator 2 X 4GB (1333)
CASE = Bitfenix Prodigy (Mesh front panel)
I am thinking about an new build but for some reasons, I am still hesitating. So I thought about an upgrade.
The system was built in Feb 2013 and it has been running since then for more than 6 years now except the GPU which is recently replaced. As an upgrade, I like to replace the case and the cooling system as well as the power supply unit.
I will use a mATX case most likely, but I get stuck at the cooling system. There are 2 considerations:
1) 240mm AIO
2) which brand?
My other worries are
(a) do all 240mm AIO comes with PWM fans?
(b) given my current Corsair Hydro Series H60 has been running on a daily basis for the last 6 years, will newer AIO products last at least this long?
(c) which brand comes with the longest warranty?
Anyone can reply with useful suggestions and opinions will be great;y appreciated, thanks in advance.
https://linustechtips.com/topic/1101963-replacement-of-corsair-hydro-series-h60-aio/
a. as far as i'm aware most (if not all) do
b. no, it's rather uncommon for an aio to last that long, hence my general preference for air coolers
c. this can vary per model, but most only have software integration and fans different from eachother these days
Skip the AIO and get a half decent air cooler, and then that money towards something useful
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
GREAT Information, all of you, really appreciate.
But I am a bit surprised to learn that Air coolers are more robust than AIO?
Would you elaborate a bit more why that is so?  As a matter of fact, I do suspect if the water inside an AIO system solidify(meaning becoming thicker and thick like porridge after years of use), is that why you say AIO doesn't last that long?
So is my Corsair Hydro in fact is not functioning?
Sources?
There are plenty of stories of AIO's failing but those with failures tend to be more vocal than those with a working product.
I don't think Corsair warranties would be 5 years if they didn't last at least that long. Not saying that warranties are always an indicator for longevity but I think this is one of those cases.
AIO's use pumps along with fans and can also leak. Air coolers use fans. More parts = higher chance of a part failing.
If your temps are fine, it's still working.
5 hours ago, WoodenMarker said:
Sources?
That's a good point, actually I don't know if it is still working fine as there are no indicator which tells me so.
The idle temperature is hovering around the 30s.
When underload, it could go up to high 60s when playing DX12 games like Civilization 6. So, is it still "healthy"?
If it is, then Corsair has really done a good job.
Actually I don't know what brand I am going to get next, could anyone give me some advices?
Yeah, seems like it's working just fine.
Is there any reason you'd want a new AIO as opposed to keeping the current cooler or getting an air cooler?
Six years, maybe the current AIO is not performing 100% efficient anymore.
60-70c is still good. There's probably some degree of degradation but it doesn't seem very significant considering the results.
Nevermind, I have decided to go for a open solution - caseless PC. The whole setup will be on my desk!
