2 minutes ago, Protongog said:
Hi all
I was pondering a new GPU and I like a little bit of 1440p 60hz and a lot of 1080p 144hz. My question is do I go for a high end 5700 or a low end 5700xt, in the UK they retail about the same cost.
Any Thoughts
If your playing at 1080p then I would get the 5700 and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1101947-radeon-5700-or-5700xt/#findComment-12871098
What do you mean with "high" and "low" end? the xt is faster than the 5700, so if thats what you mean then you should retype it. Now, when it comes to which one to choose, i would peronally go for the 5700xt in this case. As you state above, they retail for about the same price where you live, so why not spend like 10-50$ more for the 5700xt.
https://linustechtips.com/topic/1101947-radeon-5700-or-5700xt/#findComment-12871118
5 minutes ago, Protongog said:
Hi all
Any Thoughts
The 5700 XT obviously. Get an aftermarket cooler and enjoy near 2070S performance for cheap
https://linustechtips.com/topic/1101947-radeon-5700-or-5700xt/#findComment-12871121
But:
 1440p 60hz
OP is obvs playing at both 1080p and 1440p. The 5700 will drive 1080p144 and 1440p60, but I'd still go for the 5700 XT. Opens up supersampling, maybe some dabbling in 4K, or pushing 1440p144Hz if you decide to move to just one res (1440p144 is pretty much the sweet spot for most gaming).
Also:
If it's a small difference, why not get the faster card?
Main PC
CPU: i5 12600KF
Cooler: Noctua NH-L12S
Motherboard: ASRock Z690 ITX/ax
RAM: 2x16GB 3600Mhz DDR4
GPU: Intel ARC A770 16GB LE
Storage: 1TB MP34 + 2TB P41 + 2x 1TB MX500
ODD: LG WH14NS40
PSU: EVGA 850W GM
Case: Silverstone Sugo 14
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 15" M3 MacBook Air (work) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, flash, running Rockbox), Nintendo Switch
Vehicles: 2002 Ford F150, 2022 Kawasaki KLR650
https://linustechtips.com/topic/1101947-radeon-5700-or-5700xt/#findComment-12871124
11 minutes ago, Zando Bob said:
But:
Also:
I guess it sorta matters what monitor you have.  At 60hz vsync Your frame rate will never drop below 59fps lol,,,   You would get triple digits frame rates but def 60fps sustained.
https://linustechtips.com/topic/1101947-radeon-5700-or-5700xt/#findComment-12871170
It might be just me but I'd still prefer the reference 5700XT at a good discount like we've been seeing than the utmost expensive high end vanilla 5700.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1101947-radeon-5700-or-5700xt/#findComment-12871188
Probably means reference vs high end aftermarket
Want to custom loop?  Ask me more if you are curious
https://linustechtips.com/topic/1101947-radeon-5700-or-5700xt/#findComment-12871192
5700xt for sure. I went from a 2060 to a 2070 at 1080p 144hz and can turn the settings up higher and keep better frame rates at the same time. Always get the card that’s a tier above if it’s close in price
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Xfx 7900gre
Fractal Ion 2+ 860watt platinum
Be quiet 500dx
Samsung G8 Oled Ultrawide
Aoc Q27G3XMN mini led
Xbox series x
https://linustechtips.com/topic/1101947-radeon-5700-or-5700xt/#findComment-12871600
