Just a theory but I'm fathoming 512GB to 1TB of RAM put into a RAMDrive then used as a storage volume in UNRAID, to provide a truly ram-like speediness to an OS and the programs running on the OS. Has this been done before, in testing? Does anyone have the ability to test this out?
https://linustechtips.com/topic/1101867-unraid-for-massive-ramdrive-based-os/
I don't see why not, but the overhead from UNRAID and the server cpu  (most likely EPYC, would recommend the 7xx2 series) would negate any advantages, as you lose on clocks, + unraid overhead.
StreamFX Ambassador (s.xaymar.com/streamfx-dc for support)
Zephyrus G14 (5900HS, 3060) running Fedora i3 and some 14nm Skylake for hosting linux repos
Do you really think you'd lose that much performance in the process? I don't personally known how UNRAID goes, though. At the end of the day, I really really just wanna see benchmarks for it but I know it's an extremely specialist class of people who could even try.
On 9/7/2019 at 1:52 AM, BruceWayneofLosSanto said:
Maybe optane would better suite, I can barely tell the difference between a ramdisk and running from optane.
Optane would be the logical answer for practical stuff, but personally I want to see a 100% Ramdisk OS
