What is the difference between chipset temperature and cpu temperature in bios?
Go to solution Solved by Jurrunio,
CPU temp could be CPU itself or CPU socket, so you should go after the CPU temp SVI2 reading in HWinfo for CPU temperature.
Chipset is the X570 chipset, on the right of the PCIe slots under the graphics card
PCIe x16 temp probably means the tpp x16 slot
VR Mos means the VRM of the CPU on the board, under the heatsinks.
Hi all, i have an aorus x570 elite motherboard and am kind of confused as to what some of the temperatures are for(this is my first pc so am a novice). I have the cpu and chipset temperatures that are both different(i assumed the chipset was the cpu but am getting two different readings) i also dont understand what system 1, system 2, pciex 16 and vrm mos temperatures are for and what the safe temperatures for these components are. If anyone could clear this up for me that would be much appreciated.
P. S if you know of any programs that can help me monitor the vrm, pciex and system temperatures without having to access the bios that would be great
Desktop benching:
21 hours ago, RAM555789 said:
The chipset connects the CPU to the rest of the computer hardware.
thanks for the help.
