I've been messing around with this build for a while, but i'm scared that it won't work for one reason or another. This is my first ever build, so all I'm asking is, is this build good enough to work out. I used pc part picker, this seemed like the easiest way for me and you to understand. This is my budget, so you don't need to suggest any other expensive items.
PCPartPicker Part List: https://pcpartpicker.com/list/zWtJzY
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($193.89 @ OutletPC)
Motherboard: Gigabyte X570 AORUS ELITE ATX AM4 Motherboard  ($199.99 @ Amazon)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory  ($69.99 @ Amazon)
Storage: Crucial MX500 1 TB 2.5" Solid State Drive  ($107.99 @ Adorama)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB WINDFORCE OC Video Card
Case: Corsair SPEC-06 ATX Mid Tower Case  ($99.99 @ Walmart)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  ($89.89 @ OutletPC)
Total: $761.74
Thanks in advance! :)
https://linustechtips.com/topic/1101303-i-need-confirmation-about-my-first-build/
3 minutes ago, NoMoRewinds said:
I've been messing around with this build for a while, but i'm scared that it won't work for one reason or another. This is my first ever build, so all I'm asking is, is this build good enough to work out. Sorry that the screenshot is in dutch, but this seemed like the easiest way for me and you to understand. This is my budget, so you don't need to suggest any other expensive items.
Total: $761.74
Looks like you haven't factored in the RTX 2070 in that total.
If you haven't already bought the items I would recommend going with a different brand than Gigabyte for your graphics card as they tend to have cooling issues and are an all around low end brand for almost the same price as other manufactures such as Asus or EVGA.
R U L E  # 1   A b o u t   M e:   I   u s u a l l y   g i v e   D U M B   a d v i c e   a n d   y o u   s h o u l d   n o t   l i s t e n   t o  m e.
I have experience with them I believe they have a good warranty, however I wouldn't go with them if I were you.
That EVGA graphics card looks good. However I don't believe that you need a X570 board, I'm not sure though, I will ask the community. The other thing is I have not herd of "Azerty" as I am a US citizen that is probably why. I would recommend ordering off of amazon if it is available to you.
Ok, I checked with the community and these are two of the best answers:
Slottr said:
"One reason could be that you would need a bios update, but that's really it. Go look at a B450 Tomahawk though. Performs just as well as an X470 board and you only lose SLI, which you shouldn't need anyways depending on your workload"
Vejnemojnen said: "Depends on budget. I would wager, you shall be fine even on a B450 mobo. I see no reason against the latter"
I would recommend this motherboard: https://pcpartpicker.com/product/6hF48d/asus-prime-x470-pro-atx-am4-motherboard-prime-x470-pro this is the one I have and have been very pleased with it. If you do get a different one try going with either Asus or msi. If you don't mind paying the extra the motherboard you picked out looks awesome.
Consider using the MSI B450 Tomahawk MAX motherboard.
I'd also suggest the 1TB Intel 660p NVMe drive. Faster than the SATA III MX500, but lower write endurance. However, the rated endurance works out to more than 50GB written every day for 10 years.
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (€198.95 @ Megekko)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  (€124.95 @ CD-ROM-LAND)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory  (€97.85 @ Megekko)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive  (€104.90 @ Megekko)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB WINDFORCE OC Video Card  (€573.95 @ CD-ROM-LAND)
Case: Corsair SPEC-06 ATX Mid Tower Case  (€94.00 @ Paradigit)
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  (€75.99 @ Megekko)
Total: €1270.59
Generated by PCPartPicker 2019-09-04 21:53 CEST+0200
Where are you getting that info from regarding cooling issues ?
How do you figure that Gigabyte are a low end brand ? That is just not true at all.
