Assuming the fan has low enough resistance: It'll spin extremely slowly assuming the 5v is actually outputting the full 5v at the moment. Otherwise, it'll just sit there getting hot from electrical resistance
PLEASE QUOTE ME IF YOU ARE REPLYING TO ME
Desktop Build: Ryzen 7 2700X @ 4.0GHz, AsRock Fatal1ty X370 Professional Gaming, 48GB Corsair DDR4 @ 3000MHz, RX5700 XT 8GB Sapphire Nitro+, Benq XL2730 1440p 144Hz FS
Retro Build: Intel Pentium III @ 500 MHz, Dell Optiplex G1 Full AT Tower, 768MB SDRAM @ 133MHz, Integrated Graphics, Generic 1024x768 60Hz Monitor
35 minutes ago, Jas99 said:
I have it plugged into the correct power header but I'm talking about the rgb connector
Image result for 5v rgb header pinout
Image result for pwm fan pinout
Depending on which way the fan was plugged into the header either
A) The fan would spin extremely slowly backwards and put a marginal voltage to your Data line on the RGB header
B) Not spin but hot from too much resistance and put a marginal voltage to your Data line on the RGB header
C) Nothing at all since pin 3 reports fan speed and pin 4 controls fan speed
