9 minutes ago, The Torrent said:
So if the base is 3.6 and the boost is 4.2, and I overclock to 4ghz, will the boost go to 4.6?
ok it should, it doesn’t on my pc?
how does it work with overclocking.
No.  If you set the multiplier to anything other than the base multiplier then it will stay at the multiplier you set.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
This logic only apply on GPUs when thermals are not a concern. CPUs just lock to your new multiplier.
that's why you shouldnt touch the multipliers on Ryzen 3rd gen. You wont reach as high as it does at stock settings.
Desktop benching:
So your basically worse off if you overclock ryzen?
3rd gen, yes. 1st and 2nd gen's boost algorithm isnt as good so manual overclocking is still preferable on CPUs that isnt the 2700x.
Desktop benching:
27 minutes ago, Origami Cactus said:
Usually boost gets disabled if you overclock by changing the frequency.
Can you overclock without changing the frequency?
Personal Desktop":
Luna, the temporary Desktop:
What about if your overclocking above boost frequency? I have my 3600 at 4.5ghz
Does benchmark scores reflect 4.5GHz tho?
Desktop benching:
27 minutes ago, The Torrent said:
Like 4.3 on cpu z bench still higher than 4.2
If you dont score as the frequency suggests then you're not stable at that.
Just drop the frequency to 4.3 then, you might gain performance but I doubt if it's very noticeable.
Desktop benching:
really? What other methods are there of testing overclock stability??
imo Sisoft Sandra. It runs long and produces a score that you can evaluate whether it corresponds with the frequency jump. I dont have 3rd gen Ryzen on hand though so I'm not sure if it's the most stressful.
Desktop benching:
  • 2 months later...
Cinebench r15 or r20 for initial stability test
Prime95/Aida64/OCCT/Asus Realbench for min 6 hours.
Use your computer normally and play all your games for a long session
Put your computer into sleep or hib for a long time then wake it up
If you pass all of these without any crash, freeze, or bsod then your oc is stable.
