https://linustechtips.com/topic/1100402-please-help-with-my-pc-part-picker-list/
The warning message in red is regarding the BIOS version. B450 motherboards, while physically compatible, came out before Ryzen 3rd gen, so you'd need an older CPU to update the BIOS. If you contact AMD support, they'll lend you one as long as you have proof of purchase for your motherboard. As for the orange ones, they hardly matter, just take into account what they describe for when you plan future upgrades.
Primary PC:
english please
Just now, ThriversCap said:
english please
B450 old, Ryzen 5 3600 new. Update BIOS with a borrowed CPU from AMD, just keep your Newegg receipt for the motherboard.
Ignore orange warnings on PCpp.
Primary PC:
ok i just wanna avoid this sowait whats a good motherboard that is compatible with the pc and that cpu
out of the box, MSI motherboards labeled MAX are updated for Ryzen 3rd gen, but they don't show up on pcpp. X570 motherboards work too, but they're a touch expensive, with the cheapest coming in above $200 CAD.
The other alternative is to get a motherboard with a BIOS flash button, so you can update it without a CPU installed. In your price range, an option such as the B450 gaming plus would work pretty well.
https://ca.pcpartpicker.com/product/3YhKHx/msi-b450-gaming-plus-atx-am4-motherboard-b450-gaming-plus
Primary PC:
ok so will this work
the B450-A Pro has bios flashback.
Missed that on the spec sheet, oops
Primary PC:
1 hour ago, ThriversCap said:
with my pcpartpicker list i was almost 100% sure it was perfect but it comes up with the warning message do you think its a problem
MADE THIS You MADE THIS ? I MADE THIS face white text black and white facial expression cartoon mammal person nose vertebrate font head line art emotion human behavior drawing hand organism line organ
1 minute ago, ThriversCap said:
imaa just use the upgraded motherboard
just get the B450-A Pro, download the file from MSI's product webpage and put it in a thumbdrive, then if it doesn't boot right away you plug in the thumbdrive into the motherboard and push the button at the back.
whel this is for a friend and we still have like 700 dollars in his budget and i dont want to put this pressure of this on him and he doesnt want me building the pc just designing it so imma just upgrade and do you think this will work
show him this, if he can transfer files with a thumbdrive, he can flash the BIOS with it.
ok i think this will be good but i will run it by th person that will be building it but JUST in case will the other board work
all X570 boards will work with the 3600 without needing a BIOS update.
