hello, i was wondering if any of you guys could make a part list for me thats sub $800 that can handle mid level games (overwatch, minecraft, fortnite, apex, etc) this would be much appreciated.
ps. the list is just the pc components like the gpu, cpu, case, cpu cooler, storage, motherboard, ram, power supply,) NOT INCLUDING THE MONITOR OR ANY PERIPHERALS.
thx,
gamer on a budget
https://linustechtips.com/topic/1100114-please-help-me-make-a-budget-build/
10 minutes ago, ItzKunal said:
US?
which country?
1 minute ago, ItzKunal said:
yes
Then it looks like you  can just barely get an RX 5700 into the system, before taxes anyways.
You can just not use a case for a while if you have to cut it to make the budget.
PCPartPicker Part List: https://pcpartpicker.com/list/ZVcww6
CPU: AMD Ryzen 5 1600 3.2 GHz 6-Core Processor  ($169.45 @ OutletPC)
Motherboard: ASRock B450M Pro4-F Micro ATX AM4 Motherboard  ($71.00 @ Amazon)
Memory: GeIL EVO POTENZA 16 GB (2 x 8 GB) DDR4-3000 Memory  ($59.99 @ Newegg)
Storage: HP EX920 256 GB M.2-2280 NVME Solid State Drive  ($45.89 @ OutletPC)
Video Card: ASRock Radeon RX 5700 8 GB Video Card  ($329.99 @ Newegg)
Case: Cougar MX330-X ATX Mid Tower Case  ($44.98 @ Newegg)
Power Supply: Cooler Master MWE Gold 550 W 80+ Gold Certified ATX Power Supply  ($64.99 @ Amazon)
Total: $786.29
Generated by PCPartPicker 2019-09-01 01:22 EDT-0400
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($129.30 @ Amazon)
Storage: TCSunBow X3 480 GB 2.5" Solid State Drive  ($48.99 @ Amazon)
Video Card: Sapphire Radeon RX 5700 XT 8 GB Video Card  ($399.99 @ B&H)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($38.00 @ Amazon)
Total: $812.26
Generated by PCPartPicker 2019-09-01 01:26 EDT-0400
2 minutes ago, Genwyn said:
First gen ryzen, 3000mhz DDR4, micro atx board in an ATX case
Can tell this took you all of maybe 3 seconds to put together.
Maybe a 5700 should not be the baseline component for an 800$ build.
There's nothing wrong with any of that, it's the most basic motherboard for a low price, although for some reason the Gaming Plus is at a regular price, so that's better.
But the GPU is the most important thing in a gaming PC anyways. First Gen Ryzen is fine.
Assuming this motherboard gets BIos updates, he can upgrade to Ryzen 4000 next year or something.
Why on earth is the 2600 so cheap?
PCPartPicker Part List: https://pcpartpicker.com/list/bxsTbX
Motherboard: MSI B450M GAMING PLUS Micro ATX AM4 Motherboard  ($84.99 @ Amazon)
Total: $760.13
Generated by PCPartPicker 2019-09-01 01:28 EDT-0400
