HDR 10 rating vs VESA certified displayhdr 600?
Go to solution Solved by Fasauceome,
HDR 10 means a peak brightness of 1000 nits, but DisplayHDR 600 has a peak brightness of 600 nits
I'm looking at some monitors and when I was comparing them one of the differences was one has an HDR 10 rating while the other had a VESA certified displayhdr 600. What is the difference between these two ratings? From what I believe one monitors just has a sticker that the other doesn't but they're the same. Is that correct?
Current Pc Parts:
-CPU: Intel i7-9700k
-GPU: EVGA RTX 2070 black edition
-CPU Cooler: NZXT Kraken x62
-Mobo: Asus z390-E gaming
-Ram: Corsair Vengeance RGB pro 32g @3000MHz
-Storage: Samsung 850evo 256Gb
-Storage: Toshiba 1Tb 7200rpm
-Case: NZXT H500
-Extra: NZXT Hue 2
Primary PC:
