Posted August 31, 2019 Hi guys I broke one of the fins off the strix 1070ti. The card is wobbling now due to the fan being unbalanced. It's the last fan sonits in series so I can't just unplug the fan. I've ordered a replacement but it's from China so can take a while. If I cut the fan cables. Would it still be ok with just two fans? Folding Stats SYSTEM SPEC AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro Sound Logitech Z560 THX | Operating System Windows 10 Pro Link to comment https://linustechtips.com/topic/1099949-help-gfx-card-fan/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 31, 2019 8 minutes ago, shaz2sxy said: Cut the cables??, Why?? CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm. Link to comment https://linustechtips.com/topic/1099949-help-gfx-card-fan/#findComment-12855617 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 31, 2019 Author 10 minutes ago, Constantin said: Cut the cables??, Why?? So I can still run the other two fans Folding Stats SYSTEM SPEC AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro Sound Logitech Z560 THX | Operating System Windows 10 Pro Link to comment https://linustechtips.com/topic/1099949-help-gfx-card-fan/#findComment-12855640 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 31, 2019 1 minute ago, shaz2sxy said: So I can still run the other two fans Why what will happen if you plug the 3rd fan without a fin? CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm. Link to comment https://linustechtips.com/topic/1099949-help-gfx-card-fan/#findComment-12855644 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 31, 2019 Author 37 minutes ago, Constantin said: Why what will happen if you plug the 3rd fan without a fin? It makes the gfx card wobbles as soon as it speeds up. Folding Stats SYSTEM SPEC AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro Sound Logitech Z560 THX | Operating System Windows 10 Pro Link to comment https://linustechtips.com/topic/1099949-help-gfx-card-fan/#findComment-12855760 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 31, 2019 Author Well, i snipped it off, Only issue is that it runs the remaining fans at 100% lol at least it wont overheat... now just have to wait for the replacement via China Folding Stats SYSTEM SPEC AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro Sound Logitech Z560 THX | Operating System Windows 10 Pro Link to comment https://linustechtips.com/topic/1099949-help-gfx-card-fan/#findComment-12855908 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
