Are my stock voltages and temps too high? 1.42v stock ryzen 3600 set on auto.
Just turned on my new build first time.
ryzen 3600 Corsair h115i platinum plugged into cpu opt. Looks like my cpu temp is 45 degrees and core voltage is automatically around 1.42ish v. Is it meant to be this high as stock?
1.42V is right around the max for Ryzen chips while overclocked afaik, is any auto overclocking enabled?
Builds:
No I just turned it on. It’s set to auto,
first even boot up. What could be wrong with it?
So everything is on auto? Does it stay st 1.42 or does it fluctuate? What does ryzen master report
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
What is ryzen master? I have not downloaded any os yet only just booted the pc up first time into bios.
it fluctuates between like 1.36 and 1.42 mostly around 1.41
This is normal at 100% stock settings. At idle/low usage, voltages will always be high. My 3700x at idle on stock would sit between 1.45-1.5v and would drastically drop when under load, usually down into the 1.1-1.2v range.
"Black Out"
Dedicated Streaming Rig
Ryzen master is amds software for OC/check temps/check voltages etc etc
https://www.amd.com/en/technologies/ryzen-master
Ok I’ll get windows loaded on and download thst.
It’s normal? Internet was telling me not. It won’t fry the cpu or anything right?
Then that's normal. Bios doesn't exactly idle in a C state
no it wont, however I dont like it and neither do others, for good reason as it is high. I personally have mine set to 1.35v at 4.2ghz in BIOS.
"Black Out"
The real max for Zen is 1.45v. anything under that is perfectly safe. The thermals are also excellent. Tj max on Zen is 90
What about temps. 45c idle 18c ambient h115 platinum cooler
Thermals are good? Cuz I saw people on the internet sitting st 30c with air coolers and this aio is only doing 45 with 18c ambient.
i know some air can be better ok
You are not idle currently. The bios doesn't enter an idle c state. You are in a high performance state running at max auto clock and voltage
Let me guess, MSI bios?
No asus b450 f
Hmm, odd. Asus doesn't usually have such heavy overvoltage on their AM4 boards. Anyhow, the bios runs notably hotter than windows idle because the CPU is currently in a high performance state and not in a low power c state like in windows. Once you boot up Ryzen master, I expect lower clocks, voltages and temps at idle
There are fine but in bios the pc isn’t ‘idle’ - install windows 10 and see temps then and report back.
If you have done no manual oc’ing I would t worry much. Just pbo doing its thing I believe
If you think it’s anything extra out of ordinary do let me know if you think it’s worth emailing where I purchased the board from (scan).
Nah, it's nothing to worry about - probably overprovisioning for the X models.
It isn’t an x model.
o oh
I mean it probably detects a six-core and automatically gives it enough voltage for an X model - could have been done to save BIOS space since we know that was a bit of a tight squeeze with motherboard manufacturers not used to motherboards supporting 3-4 generations of processors
  • 4 weeks later...
hello there i have a r5 3600 i am in the aorus elite mainboard x570 and i am using the stok cooler
for now and the temps is 45-50 idle in windows 10 ryzen balance plan and in stress test it goes 93 celcius thats normal ? always the case is the old cooler master elite 330 so the airflow is not very good....
is safe to work it like that
sorry for my poor english...
its probably safe as your not gonna be constantly stressing it in games.. You should really get some better airflow there though.
