ac 7265 wifi not being detected.
Go to solution Solved by LeadFlames,
Just now, Alex Atkin UK said:
Maybe the CNVI slot ONLY works with CNVI cards?
Yes maybe, couldn't find a support list for CNVI cards just AC 9560 and looked at the MSI motherboard its also using a 9000 card so...
I'll order an AC 9560 and see what happens.
Hello world.
I've recently bought an ac 7265 m.2 wifi card and installed in to my motherboard a Gigabyte Z390 M GAMING mATX, and is not being picked up device manager, the intel wifi drivers are also installed.
Setup as Follows:
Z390(CUnet)(noise_scale)(Level3)(x4.000000).thumb.png.52e0ea74aac4cb021bfb7eccd547eb9b.png
I think it might have to do with the ssd (raid 0) installed and pcie lane allocation or maybe the i3
Hope some can help and thank-you for your time, cheers.
https://linustechtips.com/topic/1099829-ac-7265-wifi-not-being-detected/
You tried the other pcie x slot underneath the one you are using now?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
8 minutes ago, LeadFlames said:
The ac 7265 is in the CNVI slot, so it doesn't do the regular pcie slots.
Oh my bad. Not sure check your manual if it says anything about certain slots being disabled when using both m.2 slots
44 minutes ago, LeadFlames said:
The manual only talks about disabling sata connectors non of which i'm using.
Hmm.. not sure in that case. Can you see the device in your bios?
6 minutes ago, LeadFlames said:
No I can't
That’s odd. Means your mobo isn’t picking it up at all. You said you might think it have to do with pcie lane location, did you tinker with them?
