So I was watching youtube on my computer and it randomly shut down. I tried to turn it on but it refused to. I unplugged and switched the psu and it still didn’t work. I tried jumping the psu and the fans spun. I tested it in another motherboard and that motherboard worked. Is there a way I can repair my motherboard, why did it randomly die and what should I do if it can’t?
Current Gaming build:
Specs:
CPU: AMD Ryzen 7 3800x
CPU Cooler: Corsair H100i Platinum
Motherboard: ASRock X570 Taichi
Memory: 2x8GB Corsair Vengeance RGB Pro 3000mhz 15-17-17-35
Graphics Card: Geforce RTX 2080
Graphics Card Cooler: EVGA XC Ultra Gaming
Storage: 500GB Samsung 860 EVO, 1TB Western Digital Blue
PSU: Thermaltake Smartpower 750W
Case: Corsair 460x Black
Case Cooling: A mix and match of fans ?
Peripherals:
Monitor: HP 27ea
Keyboard: Corsair K70 RGB MK.2 SE
Mouse: Corsair Glaive Black
Headphones: Corsair HS60
Microphone: Blue Snowball Black Edition
"Gaming" Laptop: Apple MacBook Pro Mid-2012 with Nvidia Geforce Now
https://linustechtips.com/topic/1099791-pc-presumably-mobo-died-and-i-need-help/
You didn't test your RAM, your CPU or anything other than your PSU, so jumping to the conclusion that your motherboard died is way premature.
Well, I don’t know why it would post with the cpu, ram and psu the same but the motherboard different. Also I tested the PSU and it worked as I jumped it and it powered fans. Also how am I supposed to test it if the PC won’t boot without a motherboard switch?
Specs:
Peripherals:
Monitor: HP 27ea
Mate, you are being incoherent. Did you or did you not test the CPU, RAM, GPU and everything else in another mobo?
I tested the psu, gpu and the mobo. The gpu did not stop it from booting, and i jumped the psu and it powered the fans fine. However, when I switched the motherboard it booted.
Specs:
Peripherals:
Monitor: HP 27ea
If you tested with another mobo, another CPU and other RAM-sticks, how do you know it's not your RAM that is broken? Or your CPU? Like I said, if you haven't tested all those then you don't actually know if the mobo is broken or something else.
This is a good point but, why would it only be broken with a certain motherboard but work fine on my other motherboard?
Specs:
Peripherals:
Monitor: HP 27ea
What are you talking about? The PSU? Or what?
I am talking about the CPU, RAM and VGA. You suggested they may be broken, but I don’t understand why they would only be broken with a certain motherboard.
Specs:
Peripherals:
Monitor: HP 27ea
I never said anything like that.
Ok. Anyways if you have help or advice let me know.
Specs:
Peripherals:
Monitor: HP 27ea
Well, there is nothing that you can do about a broken mobo. If the mobo is broken, you'll need a new one.
Ok. I was just wondering if fixes i could try exist.
Specs:
Peripherals:
Monitor: HP 27ea
this was confusing. if you did try the same ram and cpu on a separate motherboard, then not many easy things you can do with the board other than reset CMOS if you haven't already
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
Ooh good idea. I do need to try a cmos reset
Specs:
Peripherals:
Monitor: HP 27ea
I just tried CMOS reset, and it did not work.
Specs:
Peripherals:
Monitor: HP 27ea
