There are cheaper 250-ish GB M.2 PCIe x4 drives out there. Adata and Inland both have solid offerings around the $40 mark. Go with an RX 5700 over an RX 580. It'll cost a little more, but you'll thank yourself later.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/1099787-opinions-on-my-build/#findComment-12854463
Motherboard with built in wifi.
Better PSU.
Much faster GPU.
Cheaper case but with much better airflow.
Cheaper than your build.
You can even take non X CPU to save even more.
Main system: Ryzen 7 7800X3D / Asus ROG Strix B650E / G.Skill Trident Z5 NEO 32GB 6000Mhz / Powercolor RX 7900 XTX Red Devil/ EVGA 750W GQ / NZXT H5 Flow
https://linustechtips.com/topic/1099787-opinions-on-my-build/#findComment-12854470
Better PSU.
Much faster GPU.
A better cheaper version:
PCPartPicker Part List: https://pcpartpicker.com/list/Lcfz8Y
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($129.30 @ Amazon)
Motherboard: Gigabyte B450 AORUS PRO WIFI (rev. 1.0) ATX AM4 Motherboard  ($119.89 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($64.99 @ Amazon)
Storage: Intel 760p Series 256 GB M.2-2280 NVME Solid State Drive  ($47.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  ($44.53 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1660 Ti 6 GB WINDFORCE OC Video Card  ($249.99 @ Newegg)
Case: Cooler Master MasterBox MB511 RGB ATX Mid Tower Case  ($79.99 @ Newegg)
Power Supply: Corsair RMx (2018) 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($79.99 @ Newegg)
Total: $816.57
Generated by PCPartPicker 2019-08-31 00:41 EDT-0400
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
https://linustechtips.com/topic/1099787-opinions-on-my-build/#findComment-12854478
Total: $816.57
I missed that Gigabyte GPU price drop. My bad.
https://linustechtips.com/topic/1099787-opinions-on-my-build/#findComment-12854484
Motherboard: ASRock B450M/AC Micro ATX AM4 Motherboard  ($89.99 @ Amazon)
Memory: OLOy WarHawk RGB 16 GB (2 x 8 GB) DDR4-3200 Memory  ($66.99 @ Newegg)
Storage: Sabrent Rocket 512 GB M.2-2280 NVME Solid State Drive  ($59.98 @ Amazon)
Video Card: MSI Radeon RX 5700 XT 8 GB EVOKE OC Video Card  ($429.99 @ Newegg)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($38.00 @ Amazon)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($59.99 @ Amazon)
Total: $874.24
Generated by PCPartPicker 2019-08-31 01:01 EDT-0400
https://linustechtips.com/topic/1099787-opinions-on-my-build/#findComment-12854509
Total: $874.24
The MSI EVOKE?!,really?
The memory in this card is extremely hot,
for some reason MSI ship them with only half of a thermal pad per module SMH.
Also the cooler does not fully cover the memory modules
https://linustechtips.com/topic/1099787-opinions-on-my-build/#findComment-12854544
it's the only AIB card in stock.
https://linustechtips.com/topic/1099787-opinions-on-my-build/#findComment-12854549
