Need a new/different air cooler
Go to solution Solved by Jakub_NF,
2 minutes ago, salatji said:
To be clear: The regular Dark Rock, not the Pro?
Also: Do I need a special mount for the Dark Rock 4? If I use the filters in mindfactory on AM4 the Dark Rock 4 does not show up.
The Pro would be even better but also pretty overkill for your cpu. Both of them come with AM4 mounting brackets.
From Dark Rock 4 compatibility list: LGA 1150 (Socket H3), LGA 1151 (Socket H4), LGA 1155 (Socket H2), LGA 1156 (Socket H), LGA 1366 (Socket B), LGA 2011 (Socket R), LGA 2011-v3 (Socket R), LGA 2066, Buchse AM2, Buchse AM2+, Buchse AM3, Socket AM3+, Socket AM4, Socket FM1, Socket FM2, Socket FM2+
Hey, for reasons I need a different air cooler for my Ryzen 1600x. In addition to that I use a X370 MSI gaming pro (if that even matters).
My budget would be 50-70€ and I live in germany.
I wonder if there are Noctua Fans in that range, kinda hard to have a good overview over good aircoolers in that range...
https://linustechtips.com/topic/1099659-need-a-newdifferent-air-cooler/
Dark Rock 4 or Noctua NH-U12S will do the job.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
1 minute ago, salatji said:
do you know if the noctua is also available with black fans? I love the power but I really dislike the brown fans... :D
I never seen Noctua towers with black fans.
Pro 4 is beyond given budget (Its something like 90 euros right now). As for compatibility, on their website it says that it supports AM4.
https://www.bequiet.com/en/cpucooler/1376
Also Pro 4 is just a massive freaking overkill for that CPU. Even normal Dark Rock 4 is overkill.
What case and ram are you using?
Wait! Just wait!
We are gonna have some old new comers soon enough!
The all black Noctua coolers.
SILVER GLINT
CPU: AMD Ryzen 7 3700X || Motherboard: Gigabyte X570 I Aorus Pro WiFi || Memory: G.Skill Trident Z Neo 3600 MHz || GPU: Sapphire Radeon RX 5700 XT || Storage: Intel 660P Series || PSU: Corsair SF600 Platinum || Case: Phanteks Evolv Shift TG Modded || Cooling: EKWB ZMT Tubing, Velocity Strike RGB, Vector RX 5700 +XT Special Edition, EK-Quantum Kinetic FLT 120 DDC, and EK Fittings || Fans: Noctua NF-F12 (2x), NF-A14, NF-A12x15
18 hours ago, salatji said:
be quiet pure base 600 and trident Z 2x8
If you just want something functional, the Gammaxx 400 is a great value and provides ample room for oc'ing: https://de.pcpartpicker.com/product/hJFPxr/deepcool-cpu-cooler-gammaxx400
If you want something very quiet, some great alternatives include the Mugen 5 Rev. B and Ninja 5.
https://de.pcpartpicker.com/product/8GBrxr/scythe-mugen-5-rev-b-512-cfm-cpu-cooler-scmg-5100
https://de.pcpartpicker.com/product/dZ3H99/scythe-ninja-5-430-cfm-cpu-cooler-scnj-5000
Yeah, thanks for the input, I however already did order the Dark Rock 4 and installed it. I am amazed how silent my system now is and that the Dark Rock apparently keeps my cpu 5-10° cooler than my old 212 Hyper turbo...
