Currently upgrading my brothers pc and we have everything ready to go but when we press the power up, the gpu fan begins to spool up and the motherboard lights flash and then nothing
Msi x470 gaming pro motherboard
Ryzen 5 2600x
Ddr4 3000 mhz ram are the upgraded
Probably a stupid question but we took out a fan because we are looking at different placing solutions that could hardly do it ?
https://linustechtips.com/topic/1099626-motherboard-not-booting/
12 minutes ago, Caolan.Kelly said:
Zotac Gtx 970
Have you tried booting the system outside the case to make sure there is no electrical short?
Main system: Ryzen 7 7800X3D / Asus ROG Strix B650E / G.Skill Trident Z5 NEO 32GB 6000Mhz / Powercolor RX 7900 XTX Red Devil/ EVGA 750W GQ / NZXT H5 Flow
When I boot the ez debug shows a quick flash of red across all four leds,
Labelled
Cpu
Dram
VGA
Boot
Labelled
Cpu
Dram
VGA
Boot
Something I should've asked earlier - Is you monitor connected to the GPU or the motherboard?
What is the PSU?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
Just now, Caolan.Kelly said:
Gpu
Try placing RAM stick(s) into different slots or leaving only a single one (If you have multiple sticks) and booting like that.
2 minutes ago, LienusLateTips said:
What is the PSU?
Corsair cs 550
Tried connecting VGA to motherboard same problem
Tried this to no avail
