Posted August 30, 2019 Hi, Just bought the display mentioned above and I can't get it to work on 240hz. Nvidia CP shows 1080p @ 240hz, but once I choose it the screen goes black, gives maybe 2 flickers of desktop and then reverts back to 144hz. Same goes for 200hz. 144hz works fine. Using latest drivers. Tried different cables (dp1.4) and ports, G-Sync on and off etc. Other hardware: i7-7700k GTX960 270Z mobo Any ideas? Link to comment https://linustechtips.com/topic/1099484-asus-pg258q-240-200hz-problems/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 30, 2019 Can you try Display port? I don't think HDMI 2.0 supports 240hz. Magical Pineapples
