Need help setting up multiple PC's connected through two different networks
Go to solution Solved by HunterAP,
Ended up finding the solution online. My initial google searches were saying that you couldn't have multiple interface on FreeBSD / FreeNAS using the same subnet, but that apparently isn't true.
By manually setting the IP addresses of all my RJ45 connections to 192.168.1.XXX while having all the SFP+ connections use IP addresses 192.168.2.XXX, I'm not able to have the correct configuration for all my networking gear. Now I just wish the internet made it easier to find this information.
I'll try to explain my layout as best as possible.
  • PC 1: Personal Desktop using Windows 10
  • PC 2: FreeNAS Server
  • PC 3: Ubuntu Machine
Each one of these machines is using their integrated Gigabit RJ45 NIC's to connect to a small switch I have connected to my router.
Also, each of these machines has a 10Gbps SFP+ NIC connected into a MikroTik switch (CRS305-1G-4S+IN) 4 SFP+ ports and 1 gigabit RJ45 port.
To better show it, I made a chart of how it's currently set up:
So here's where the problem lies:
  1. FreeNAS does not allow for multiple NIC's to be registered as different IP's. I read one post from the FreeNAS forums that says you can't have multiple network interfaces connect through the same subnet/netmask. This is, I manually configured both the RJ45 and SFP+ NIC's to be on different subnets, but I can't connect to the FreeNAS machine from either of my other machines. Doing on a ping on either machine to the FreeNAS one results in a message
    From XXX.XXX.XXX.XXX Destination Host Unreachable
    Which from what I've read means that my router knows that IP is registered inside my home network, but it can't find a way to get to that IP. Even when I remove the gigabit network interface and only have the SFP+ one, my other machines report the same issue.
    Also just want to be clear that this issue isn't present when doing actions to/from my desktop and the Ubuntu machine, FreeNAS is the only problem there.
  2. How would I go about binding the different connections between my machines? Say I want to copy a file from my desktop to a FreeNAS machine: I want it to only use the SFP+ connection through the SFP+ switch, but right now it defaults to using the gigabit connection through the gigabit switch. For FreeNAS, I tried binding the SMB service for network drive sharing to the one on my SFP+ NIC, but it doesn't work and teh drives get disconnected.
    I'm also assuming that whatever sort of solution for this question would also help solve issue #1, or at least I'd hope so.
Might be a longshot, but... Can RJ-45 switch create multiple local networks with only one port as the output (aka isolate all clients so they couldn't be seen in local network group of RJ-45) like OpenWRT can do? https://forum.openwrt.org/t/client-isolation/13914
If yes, try it.
Purify your Windows 10/11, don't give Microsoft anything that you don't want to share.
https://drive.google.com/open?id=1ZwVs9zrM493rjD42E2Pf0YcOkaW92ZUo
Tips for folding on laptop:
Lazy man wants upgrades from the sky.
https://stats.foldingathome.org/donor/Spakes
What is the need for using a different subnet, if I could ask? Couldn't you just bridge those interfaces?
EDIT: Sorry, I didn't read carefully, but anyway couldn't bridging those two interfaces be the solution? Or maybe set those 3 on a different network (as long those 3 devices are the only present on the entire network, otherwise I suppose you have to configure the routes on the ISP router which is set as the default gateway)
