Hello Everyone
I'm Currently building a new computer (AMD), and in the market to spice things up and try out a new style of monitor as well. I've been scouring the internet and looking at all the monitors i could find in my Criteria. My Question is from everyone's experience cause it will be new to me what should i go with, or got any better suggestions.
I'm looking to buy a 32-34 inch non-Curve/Curve 1440P monitor Ultra-wide or Non-Ultra wide. I have been looking through a few of my options in this criteria and i cant quite seem to come to a conclusion on one without something outweighing my decision. Internal struggle i know XD
Monitors Ive been walking around.
MSI Optix MAG321CQR
LG 34GK950F-B
LG 32GK650F
Viotek GN
Now im no expert at all but Ive done a good amount of homework but i cant still pick. I'm Looking for something that will be a nice upgrade and a new experience for Gaming.
If you have any suggestions that fit my criteria by al means im open to any and all suggestions. ?
https://linustechtips.com/topic/1099440-monitor-desicion-help/
Both the LG models are fine. It just depends on what size you want in the end. The LG panels are good quality and are reliable as well. I have yet to have any hands on experience with the MSI model and no one I know has either. That Last model I have never even heard of but after a little research, they fit into the cheap-ish monitor range. A little research of your own on this brand might yield better results then what others could suggest.
Hope This Helps...
Cheers.
Professor G
https://linustechtips.com/topic/1099440-monitor-desicion-help/#findComment-12851695
Take a look at the MX34VQ, it's what I've been using the past year and love it
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
https://linustechtips.com/topic/1099440-monitor-desicion-help/#findComment-12851697
