artifacts caused by enough power provided to the gpu?
5 minutes ago, imajerec said:
using an 1x6 pin connector instead of an 1x8 pin one
To start with that, anything can happen.
Put the 8 pin that the card demands, step by step and check it
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
34 minutes ago, imajerec said:
is is possible that not enough power  provided to a gpu be the source to visual artifacts? for example using an 1x6 pin connector instead of an 1x8 pin one
The question which arises to me here is, what kind of GPU are you trying to power with what psu? Your psu should at least have 1 8 pin for your GPU
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
i have tried now and switch to an corsair rm650x , gpu is rx 480 sapphire nitro+  . same issue
i get lots of thin lines appearing and dissapearing fast from all angles while in game
Maybe card is dying
Just now, imajerec said:
shit lol,tried lowering memory frequency to 1750 same thing
reflashed bios as well, same
What are your temperatures under load ? And idle ?
Rx480/580 like power, so get the powertarget to 50% and test if still has problems get the clocks down 50mhz increments, if you still have problems get a voltage up by 25mv increments. if any of these works the card is giving itself to the creator or your PSU is going .
tried it mate. same thing
and it's not the psu, test it with 2 psu's now
i'd try to underclock the memory below 1750 but it seems it's not possible
Use OverdriveNtool for amd. I think you can do it with it.
hmm i tried really low frequncies with this tool.. nothing works man what causes this shit. i don't want freaking fireworks on my screen
