RTX 2070 super 100% fan speed when booting
When I boot my pc my gpu fans spin at 100% for about 3-4 seconds. After 5-10 seconds I see my bios logo and after 15 seconds windows is loading. The fans goes back to a normal speed after these 3-4 seconds. So when I am either in my bios or windows it's fine. I didn't have this problem with my previous gpu (MSI GTX 1070)
specs:
Asus B450-I (latest bios)
Ryzen 5 3600
RTX 2070 super founders
Corsair SF600 (80 plus plat)
https://linustechtips.com/topic/1099167-rtx-2070-super-100-fan-speed-when-booting/
specs:
Ryzen 5 3600
How do you know it's 100%, there is no software running to check it......
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
Just now, LeTard said:
Same noise as when I manually set them to 100% with msi afterburner.
They run quite fast also on mine till windows, but i never bother checking it...
