What's the difference between EVGA G+ and G3?
They are different in used technology, performance, build quality, noise, cables, and protections - pretty much everything two PSUs can be different at. Exact differences depend on which particular models you're comparing, which you haven't specified.
Maybe there are other better options for the price? Where are you buying from? And for what setup?
How did your previous PSU die?
  1. Well one is EVGA superNova 750G3 and the other is EVGA superNova 750w G+ both are 80plus Gold
  2. Unfortunately not according to pcpartpicker
  3. Im buying from a local retailer but here's the link if you want EVGA G+ And EVGA G3
  4. For ryzen 5 2600x and gtx 1070ti neither of them are overclocked
  5. So basically I used a 550w PSU for my setup. It served a year and turned off every time I did something really intensive (like VR)
That system will consume <300W.
What model was it? Is it still under warranty?
Have you checked the PSU tier list before deciding?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
20 minutes ago, adamgasth said:
Yes and it wasn't there
The G+ series is often reffered as G1+.
G1+ / G+ is a Tier A PSU while the G3 is Tier B. The G3 would have been Tier A if there weren't some issues it has.
As I own a G3 550W, I'm quite interested in how yours died and why it had no warranty (since those do have 7 years of warranty).
38 minutes ago, adamgasth said:
Model EVGA superNova 550w G3 And unfortunately not anymore
EVGA G3 550w come with a 7 year warranty. The G3 has only been available for a few years, so if you bought it new you should still have warranty available on it. Contact EVGA and see if you can get it replaced under warranty. That is assuming it is the PSU causing your issues.
Well I lost the reciept
The store did not lose the reciept.
And if you've registered the unit with EVGA (online), you can RMA directly through them.
Did you buy from a physical retail store or an online retailer? For online purchases you should have an email receipt as well as an order invoice in your account on the website.
