Hello dear community,
When I turn on my PC, I can notice that in the motherboard the red CPU led turns on for 3 seconds then turns off. Immediately after, the red VGA led turns on for the same 3 seconds then turns off. Afterwards they remain off and the computer works just fine for the rest of its use time.
I just recently upgraded my sistem to:
Ryzen 5 2600x
Crosair Vengenace 8x2 GB
MSI Gaming Plus B450
Zotac GTX 1060 6GB
Hyper 212 cooler master CPU cooler
Samsung EVO 500gb
Kingston SSD now 128gb
WD blue 3TB
Cooler Master MasteBox Lite 5
I monitor temperatures with MSI Afterburner:
Idle
GPU: 35-40c
CPU: 35-42c
Load (gaming)
GPU: 55-69c
CPU: 60-70c
Background:
I just recently reset windows because previously I had Intel and read that a new system is better if you change to AMD. Before I did recet windows: randomly, sometimes more frequently, the screen would suddenly freeze for aprox. 5 seconds then unfreeze to normality. Upon reseting windows, this problem is now gone.
PD: Installing the Hyper 212 was horrible and I did apply pressure, but as far as I know it was normal pressure for a CPU.
Thanks for the help!
the warning lights during boot are normal, only if they stay on and the boot fails do you have a problem.
Primary PC:
It is MSI's 'EZ Debug' feature.
If it is enabled in the BIOS (should be on the default), during POST, it will check for any CPU / RAM / VGA / HDD errors.
There should be an option in the BIOS to skip this step.
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz
  • Gigabyte Z390 Aorus Master
  • Sapphire NITRO+ RX 6800 XT S.E + EKwb Quantum Vector Full Cover Waterblock
  • 32GB G.Skill TridentZ DDR4-3000 CL14 @ DDR-3400 custom CL15 timings
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO +  500GB Samsung 980 + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Lian-Li O11 Dynamic EVO XL
  • Ekwb Custom loop + 2x EKwb Quantum Surface P360M Radiators
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
Thanks! Very informative.
Is it recommended to skip that step?
if you know the system is stable, there is no need to have it keep checking on every boot-up.
I usually turn it off once my system has been running stable for a few days/weeks, or when I've settled on a stable overclock.
Turn it back on again when you are upgrading the system, overclocking, troubleshooting, etc.
AMD Ryzen Rig
  • AMD R7-5800X
Excelent! Thanks for the advice!
