GPU for i7 2700k and power consumption
1 hour ago, Patrik Frankovic said:I agree with you but 300w seems too low. In my mind it is more like ~470w becouse oc cpu would be ~160w , gtx 1080 is ~210w and the rest ~100w. Am I wrong?
Don't use your mind, or calculators (if you do use them), or even the specifications sheets - use real world power consumption tests.
Just like you don't use "FPS calculators" or spec sheets when checking performance of a GPU (you read tests in games and FPS comparisons instead), or don't use spec sheets or "CPU calculators" (if those even existed) when checking performance of a CPU (you read tests in productivity programs instead).
Start with looking for reviews of GTX1080, your target graphics card. I use the polish website PCLab, but you can use many more who reviewed non-reference 1080s.
Here's their test setup, no need to understand the language: https://pclab.pl/art70047-2.html
They're testing ASUS GTX 1080 Strix, and use i7-6700k OCed to 4.7GHz. The rest is standard.
Since your setup will also use a non-reference 1080, an older i7 overclocked to 4.5, and the rest is standard, then we can conclude their test setup sips even more power than yours - since graphics cards are the same, processor is more powerful and the rest is the same. Right? Okay.
Now here's the power consumption testing: https://pclab.pl/art70047-29.html
The first chart is at idle, and the second is at load in Witcher 3.
As you can see, their entire system with i7-6700@4.7 and GTX1080 consumed 306W under load.
Therefore, your entire system with i7-2600@4.5 and GTX1080 will consume a very similar amount.
The power supply in their system is around 92% efficient. So, their setup only sipped around 282W from the power supply under load.
I tried to find a second source, in English. So here's Anandtech testing a GTX1080: https://www.anandtech.com/show/10325/the-nvidia-geforce-gtx-1080-and-1070-founders-edition-review/30
Their setup is i7-4960X@4.2, a processor even more power-hungry than yours, and an X79 motherboard.
Their system definitely sips more power than a setup with the same GTX1080, but a lower-power i7-2600K processor.
So in their testing, power consumption under load in Crysis 3 was 335W at the wall. Assuming 92% efficiency, that means 308W of actual power consumption.
TweakTown did a review of GTX1080 as well: https://www.tweaktown.com/reviews/7703/nvidia-geforce-gtx-1080-review-hail-king-baby/index11.html
Their setup is GTX1080 with an 8-core i7-5960X Extreme Edition, which is definitely a more power-hungry CPU than yours.
In their testing, their entire setup consumed just 230W from the wall.
So with those three sources that you can freely look at, you can come to the following conclusion: if three setups including GTX1080, and other components more powerful than yours, consume 300W under load or less, then your setup, with the same GPU and weaker rest of the parts, will also consume 300W under load or less.
