Hi,
I have MX150 2GB 15W (checked and 100% correct) in Lenovo ThinkPad T580 paired with i7-8650U and 8GB RAM.
There is common problem with MX150 GPUs (and as I read also with other similar mobile GPUs) that temp limit is set around 60-70 °C and then performance is dropped hard. GPU gets from normal ~1500Mhz to even ~400Mhz and gets almost equal performance as integrated UHD620 :D
There must be some way to override this limit to higher numbers because even it is ultrabook it is surely capable of staying around 80 °C all time. I understand that Lenovo is trying to protect chip but as I know temps to ~90 °C are "fine" for silicon...
Can we together find some final solution to make this limit higher and incerace performance of MX150 devices? Many people have problem with this as I read.
PS: We must find a way :D Or I will just sell it and buy Carbon or Razer Blade instead :D:D
Website programmer & Electrician & PC HW lover!
https://linustechtips.com/topic/1098969-mx150-throttling-on-too-low-temps/
The only thing I can think of is to download MSI Afterburner and see if you can get around it like that, though I can't help but feel the MX150 is locked down so much between power draw and thermal limits that it's not going to be that easy.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 5x 8TB WD White Label/Red (Plex) (both arrays in their respective Windows Parity storage spaces), 1TB Teamgroup MP33 (dumping ground) Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
OptiPlex 7040M
Intel Core i7 6700, 2x16GB Mushkin Redline (stuck at 2133MHz CL13), 240GB Corsair MP510, 130w Dell power brick, Windows 11 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB, PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
MSI AB can change max temp/power limit?
If the card hasn't blocked it, yes. But given how locked down the MX150 usually is, I doubt you'll be able to do anything.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
i usually lower the CPU to 60% maximum load for better thermal. i would not recommend something heavy with MX150
  Spec: Macbook Air 2017
ProcessorPU: ii5 (I5-5350U |
| RAM: 8GB LPDDR3 |
| Storage: 128GB SSD
 | GPU: Intel HD 6000 |
| Audio: JBL 450BT Wireless Headset |
MX150 is here because of heavy load. If you do not need heavy load, you should buy it without it. What is the point of dedicated GPU with performance as iGPU
It is blocked :( Any way to unblock it?
Not that I am aware of, no.
Main rig on profile
VAULT - File Server
OptiPlex 7040M
